Cable management holes won't have sharp metal edges. If they do, don't use them. :D That's where a hole usually would be but this doesn't look like one.
Opened up my computer and the holes weren't sharp, they were rather smooth, do you think that these are for cable management? and should i run my cables through these?
https://linustechtips.com/topic/474225-case-cable-management/#findComment-6355636
It doesn't look like the rounded oblong bit pushes out ? The two circle bits look too small for any cables to fit through.
https://linustechtips.com/topic/474225-case-cable-management/#findComment-6358668
