codeblokz problems
Go to solution Solved by Nineshadow,
What's your project like, or what are your build proprieties?Do you have other source files in the same project?
It looks like you have two main functions.One in a main.c file.
Delete that one.
People, please can you help me to sort this problem? I reinstalled the program three times deleting all the previous installs and it gave me the line: "gnu gcc compiler not found" so i reset the settings of the compiler to default and it didn't give me any more that line problem; but still, it doesn't build or run any working codes, here is a screenshot of it...
post-139232-0-53708400-1445773175_thumb.
any suggestions ?
( I installed the version with mingw included in it )
https://linustechtips.com/topic/473217-codeblokz-problems/
Delete that one.
https://linustechtips.com/topic/473217-codeblokz-problems/#findComment-6342679
Delete that one.
you were right, the new file wasn't completely blank, it had a hello world code by default in it
thanks a lot !
https://linustechtips.com/topic/473217-codeblokz-problems/#findComment-6342696
