Selecting k70 RGB default mode
Go to solution Solved by Inheritance,
Your problem should be gone by the time CUE 2.0 comes out. But for now i would just drag the mode to the top of the list so its always the default.
The current profile I am using (video for those curious https://instagram.com/p/9LzMGoKK4-/ ) had a series of modes in it that allow you to pick out the colour of your keyboard with this theme (as well as moba and fps varients) The issue im having is on each reboot CUE automaticly loads the 1st mode saved (in this case blue) I find having to manually pick a wee bit annoying and was wondering how to select the default mode for the keyboard/CUE to load into.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/473095-selecting-k70-rgb-default-mode/
In the CUE software right click this
and select "set as default profile"  on the profile you want. It will now choose that profile when you get to the desktop and CUE is launched.
and select "set as default profile"  the profile you want. It will now choose that profile when you get to the desktop and CUE is launched.
Im not looking for the default profile, that's fine, the default profile is what I want, its the Mode that is what im trying to set as default.
System Specs
Oh, then there is no option for that. You could rename the profile and add it again with only the mode you want but that's it.
Check out my iCUE Guide Beta Tester for Corsair
Got a Corsair Product? Got a Question?
Feel Free to PM Me ?
Was not aware that was a thing I could do tyvm, its good enough for me
System Specs
