Optical Drive issues
Go to solution Solved by Shimejii,
Well if your that worried :P Its an easy fix. Other things is get the drivers on a USB and put them on voila it works. IDK what else ya want :P
Do you play football/soccer?
Cause you look like a left-back
https://linustechtips.com/topic/472611-optical-drive-issues/#findComment-6335782
https://linustechtips.com/topic/472611-optical-drive-issues/#findComment-6335794
