Hi. i've made a program in JAVA applets. The program draw a polygon (A) with 4 randomly generated points then it draw another polygon with 4 randomly genrated point (B).
After this it compares each points of each ploygon to see if they're the same. if they are not, let say A[0] > B[0] then A[0]--. Until all the points of the old polygon A becomes the new polygon B. then it repeat. So the problem I have is that for some reason the Polygons just keep getting tinnier.
Here is my Code
(Sorry my fields are written in french ...)
package francis.groleau.games;
import java.applet.Applet;import java.awt.Dimension;import java.awt.Graphics;import java.awt.Graphics2D;import java.awt.Color;import java.awt.Polygon;import java.awt.geom.GeneralPath;import java.awt.image.BufferedImage;import java.awt.image.ImageProducer;import java.util.Random;
public class graphics extends Applet implements Runnable{                public boolean isRunning = false;                protected BufferedImage mBuffer;                protected boolean comparaisonFinni = false;                protected Polygon polygonCourant = createNewPolygon();                protected Graphics2D mGraphics;                protected Dimension mDimension;                protected int mFPS = (1000 / 9);
               public void start()               {                       isRunning = true;                       new Thread(this).start();               }
                public void stop()               {                 isRunning = false;               }
                public void init()                {                         mDimension = getSize();                         mBuffer = (BufferedImage)createImage(mDimension.width, mDimension.height);                         mGraphics = (Graphics2D)mBuffer.createGraphics();               }
               public void paint(Graphics pGraphics)               {                      pGraphics.clearRect(0, 0, mDimension.width, mDimension.height);                      Polygon polygonTmp = new Polygon();
                        if (!comparaisonFinni)                             polygonTmp = createNewPolygon();
                           for (int i = 0; i < 4; i++)                            {                                  if (polygonTmp.xpoints[i] < polygonCourant.xpoints[i])                                   {                                        polygonCourant.xpoints[i]--;                                   }                                  if (polygonTmp.xpoints[i] > polygonCourant.xpoints[i])                                  {                                        polygonCourant.xpoints[i]++;                                  }                                 if ( polygonTmp.ypoints[i] < polygonCourant.ypoints[i])                                 {                                       polygonCourant.ypoints[i]--;                                  }                                 if ( polygonTmp.ypoints[i] > polygonCourant.ypoints[i])                                  {                                       polygonCourant.ypoints[i]++;                                  }                                  if ((polygonCourant.xpoints[0] == polygonTmp.xpoints[0]) && (polygonCourant.xpoints[1] == polygonTmp.xpoints[1]) &&                                     (polygonCourant.xpoints[2] == polygonTmp.xpoints[2]) && (polygonCourant.xpoints[3] == polygonTmp.xpoints[3]) &&                                     (polygonCourant.ypoints[0] == polygonTmp.ypoints[0]) && (polygonCourant.ypoints[1] == polygonTmp.ypoints[1]) &&                                     (polygonCourant.ypoints[2] == polygonTmp.ypoints[2]) && (polygonCourant.ypoints[3] == polygonTmp.ypoints[3]))                                      {                                              comparaisonFinni = true;                                      }                             }                                pGraphics.drawPolygon(polygonCourant);
                public Polygon createNewPolygon()                {                      Random aNumber = new Random();                      int x1Points[] = new int [4];                      int y1Points[] = new int [4];
                     for (int i = 0; i < 4; i++)                     {                          x1Points[i] = aNumber.nextInt(200);                          y1Points[i] = aNumber.nextInt(300);                     }
                     Polygon lePolygon = new Polygon(x1Points, y1Points, 4);                    if (comparaisonFinni)                    {                          comparaisonFinni = false;                          polygonCourant = lePolygon;                    }                     return lePolygon;              }             public void update(Graphics pGraphics)             {                         paint(pGraphics);              }             public void run()             {                   while (isRunning)                  {                      repaint();                      try                           { Thread.sleep(mFPS); }                     catch (InterruptedException pException)                           { pException.printStackTrace(); }                }}}
https://linustechtips.com/topic/4717-need-help-for-some-random-project/
You should always post your code between code tags.
Now, I could just paste your code somewhere and format it automatically, but only have the time to say this for now.
I might edit this post or reply later.
Oh sorry i didn't know you could do that
is there anyway to keep the initial indentation because i had to do it manually... well anyways I hope it help ...
Pas certain de comprendre exactement ce que tu veux faire, mais tu regénères toujours des points aléatoires différents pour ton polygonTmp, donc forcément à chaque fois que tu entres dans ta boucle pour comparer tes points, des fois ton point de ton polygonTmp va être plus grand que polygonCourant, et le coup d'après il peut être plus petit... alors c'est possible que ton polygonCourant ne sera jamais = polygonTmp.
Tu peux peut-être commencer avec ceci, il reste encore quelques trucs à corriger mais ça te donne sûrement une piste :
protected Polygon polygonTmp = createNewPolygon();
@Override
public void start()
isRunning = true;
@Override
public void stop()
isRunning = false;
@Override
public void init()
mBuffer = (BufferedImage) createImage(mDimension.width, mDimension.height);
mGraphics = mBuffer.createGraphics();
@Override
if (polygonTmp.ypoints[i] < polygonCourant.ypoints[i])
if (polygonTmp.ypoints[i] > polygonCourant.ypoints[i])
int x1Points[] = new int[4];
int y1Points[] = new int[4];
return lePolygon;
@Override
paint(pGraphics);
@Override
public void run()
while (isRunning)
repaint();
try
Thread.sleep(mFPS);
@Override
public void start()
isRunning = true;
@Override
public void stop()
isRunning = false;
@Override
public void init()
@Override
return lePolygon;
@Override
paint(pGraphics);
@Override
public void run()
while (isRunning)
repaint();
try
Thread.sleep(mFPS);
Exact ahaha je viens de trouver l'erreur aussi .Le but était de créer deux polygon. Polygon A et Polygon B. Seulement le A est déssiné. les points du polygon A devait se dirigé tranquillement vers leur nouvel position c'est à dire les points du Polygon B mais ça marche à présent merci
i've fixed my problem it's working now !! here is the final code
import java.awt.BasicStroke;
import java.awt.Image;
import javax.crypto.spec.GCMParameterSpec;
private int width, height;
private Image offScreenImage;
private Graphics offScreenGraphics;
private Thread animationThread = null;
//number of frame per seconds for instance here it's 30FPS.
protected int mFPS = (1000 / 30);
public void start()
animationThread = new Thread(this);
animationThread.start();
public void stop()
animationThread.stop();
public void init()
//Initialized each fields.
width = getSize().width;
height = getSize().height;
offScreenImage = createImage(width, height);
offScreenGraphics = offScreenImage.getGraphics();
offScreenGraphics.setColor(Color.black);
//if the 2 polygon match create a new one
//Check if each points are the same if not increment or decrement points
//hardcoded .... chhhhh ... tssss
//Doubled buffering to eliminate flickering in the applet
offScreenGraphics.clearRect(0, 0, width, height);
offScreenGraphics.drawPolygon(polygonCourant);
((Graphics2D) offScreenGraphics).setStroke(new BasicStroke(5.0f, // Line width
BasicStroke.CAP_ROUND, // End-cap style
BasicStroke.JOIN_ROUND));
pGraphics.drawImage(offScreenImage, 0, 0, this);
//set the number in random.next to not exceed your Applet size. You can modify the Applet size in run Configuration
x1Points[i] = aNumber.nextInt(600);
y1Points[i] = aNumber.nextInt(600);
return lePolygon;
paint(pGraphics);
public void run()
Thread myThread = Thread.currentThread();
//IT'S A WHILE TRUE !!! you could maybe add a button start and set the thread value there but meh...
while(animationThread==myThread)
repaint();
try
//sets the number of frame per seconds
public void start()
public void stop()
public void init()
if (polygonTmp.xpoints < polygonCourant.xpoints)
polygonCourant.xpoints--;
if (polygonTmp.xpoints > polygonCourant.xpoints)
polygonCourant.xpoints++;
if ( polygonTmp.ypoints < polygonCourant.ypoints)
polygonCourant.ypoints--;
if ( polygonTmp.ypoints > polygonCourant.ypoints)
polygonCourant.ypoints++;
x1Points = aNumber.nextInt(600);
y1Points = aNumber.nextInt(600);
return lePolygon;
paint(pGraphics);
public void run()
repaint();
try
cant spot any changes I would make, looks pretty efficient (well as java can be :P) just for you're own sake you should drop the closed curly brackets at the end directly under there corresponding starting brackets, makes it easier to spot where loops start and stop in most text editors (like notepad++ for example).
Well done :)
He could have used a constant for the number of vertices :
final int NBR_VERTICES = 4;
Then simplify the vertices adjustment checks like this :
for (int i = 0; i < NBR_VERTICES; i++)
if (polygonTmp.xpoints[i] != polygonCourant.xpoints[i])
polygonCourant.xpoints[i] = polygonTmp.xpoints[i] < polygonCourant.xpoints[i] ? polygonCourant.xpoints[i] - 1 : polygonCourant.xpoints[i] + 1;
if (polygonTmp.ypoints[i] != polygonCourant.ypoints[i])
polygonCourant.ypoints[i] = polygonTmp.ypoints[i] < polygonCourant.ypoints[i] ? polygonCourant.ypoints[i] - 1 : polygonCourant.ypoints[i] + 1;
And also the check to see if both polygons match :
[SIZE=13px]comparaisonFinni = true;[/SIZE]
for(int i = 0; i < NBR_VERTICES; i++){
if(polygonCourant.xpoints[i] != polygonTmp.xpoints[i] || polygonCourant.ypoints[i] != polygonTmp.ypoints[i]){
break;
[SIZE=13px]}[/SIZE]
That way all you would need to do is change the constant to make it work with polygons with any given number of vertices.
