Motherboard help
Go to solution Solved by CoolBeans,
Asus ROG series would go good with it.
I don't think there are any white motherboards, but there are a lot of black ones.
http://uk.gigabyte.com/products/product-page.aspx?pid=4489#ov
https://linustechtips.com/topic/47121-motherboard-help/#findComment-624272
Any other higher end Motherboards you can recommend? No budget.
This is the highest end, closest to black motherboard I could find.
http://uk.pcpartpicker.com/part/gigabyte-motherboard-gaz87xud5h
https://linustechtips.com/topic/47121-motherboard-help/#findComment-624291
