Wireless Card Light Toggle?
Go to solution Solved by ClownFace1511,
I really don't think there is, you can either put tape over it or some blue tac. That should do the job.
So I have an ASUS PCE AC68 I think is the model in my system acting as a wireless adapter, and every night I go to bed, turn out all the lights, and finally get comfy, I notice a little blue LED flashing on the back of my PC. I examined it closer and found that it is, in fact, coming from the wireless card.
Is there any way to toggle this little light so it doesn't flicker or so it is just off all the time?
EDIT:
I ended up just saying "screw it" and snooped around my apartment for some tape. I finally found some tape, but it was blue painter's tape, so one piece didn't do much. I stacked about 15 pieces to make a "light-proof" sticker, and I put that over the LED. Hopefully if I ever remove it, it won't leave any residue on my PCI slot covers.
If anyone else has this problem, just tape it, because I'm pretty sure none of the cards have a software solution.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
https://linustechtips.com/topic/470923-wireless-card-light-toggle/
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
