Build for 2016
Any thoughts on the new setup?
I'm thinking of building a new system after February 2016 but I have only ever built one low cost system before (which booted on the first try, so I never experienced troubleshooting either). Below is my current PC and I am looking to improve upon it as much as possible while staying under $2000 USD. I intend to reuse the video card in the new computer as I really like it and I want to save money, maybe I can SLI it on a later upgrade. The plan is to give the current computer to my parents (with a far less powerful GPU I have lying around) when I have the new one done so I can't really reuse the parts. My CPU is running hot (80-90C at idle) and the GPU is taking up so much space that I can't install any more PCIe cards or HDDs in this case (probably not good for air flow either).
Current PC
Case: Thermaltake V3 BlacX Edition
Mobo: BIOSTAR H77MU3 Mini-ATX 1155 Socket
CPU: Intel I3 3225 3.3Ghz Dual Core Hyperthreaded with stock cooling
Thermal Compound: Arctic Silver 5 OEM
GPU: EVGA GTX 960 2Gb Cache with stock cooling
RAM: 16Gb Mix and Match Crucial and Micron 800Mhz Dual Channel DDR3
PSU: 800 Watt non-modular
OS: Win 7 Pro SP1 64bit
Case Fans: 1x 120mm rear exhaust fan with blue lighting
System Drive: Toshiba 1TB HDD (73GB free)
Storage Drive: WD 3TB HDD (493GB Free)
Optical Drive: ATAPI DVD/rw x16 Internal
I/O extra: 4 port USB 3.0 controller
Mods: Blue internal lighting bars but I had to take them out for space reasons when I upgraded to this GPU.
I use creative cloud and play games that are commonly a few years old (Payday 2, Skyrim, Fallout New Vegas, Dragon Age Inquisition) as I can't afford newer ones. I think an EATX board in a cube case would be good for me. I am not looking to save space on this, I have plenty of room for a larger case. My favored computer retailer is Microcenter, I can get to one of their stores in about 15 min and they are usually really good about returns. Any suggestions?
my thoughts...
keep the HDDs and PSU, sell the 960 (we win money here)
divide the ram in 8GB for the old pc and 8GB for the new one (we save money here)
sell the i3 (keep the motherboard) and add an i5 (we loss money here)
buy a "ready to use" full pc A10 for your dad's machine (add your ram)
and buy the best gpu you can buy for you
