So im modifying my Antec GX 700 case quite a lot
adding a window to side panel and adding a basement shroud but to do that i need to remove all hard drive bays.
as i only need two slots this is fine with me as i use a NAS for main storage.
so i was wondering if anyone new a case that had a drive cage that was 9cm tall max and could fit 2 hard drives.
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
https://linustechtips.com/topic/470222-removable-drive-cage/
760t ? cooler master modular case?
nah there to tall i think
https://linustechtips.com/topic/470222-removable-drive-cage/#findComment-6305374
Do you want just the drive bays or an entire case?
just the bays
https://linustechtips.com/topic/470222-removable-drive-cage/#findComment-6305463
https://linustechtips.com/topic/470222-removable-drive-cage/#findComment-6305534
