Memory Speed Help
Go to solution Solved by dragoon20005,
So does this mean my memory is running at 1866MHz? And do I still have to change my XMP mode in the BIOS?
No that just means it's capable of it and you do need to active XMP to use it
pretty much what Ryan says
you need to go to BIOS to start XMP
Today I downloaded cpu-z to check my systems specs in greater detail. When I got to the memory tab, it shows that my DRAM Frequency is hovering around 800MHz. From what I've read online, your supposed to double that speed, giving my memory 1600MHz speed. The problem im having is that I bought a 4gb ddr3 1866MHz stick of memory. Am I doing something wrong? Or was I shipped the wrong type of memory?
https://linustechtips.com/topic/469697-memory-speed-help/
does the RAM in speccy shows the 1866 model?
if they are correct
you just need to adjust the RAM speed in BIOS
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298633
In speccy it shows the DRAM frequency as 799MHz
can you post the screenshot of speccy?
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298671
Yep, https://gyazo.com/0cfc068615ef272a3270d7bbc08b6bbd Hope that is enough, its my first time using gyazo.
hmm this software cant see the model
http://www.cpuid.com/softwares/cpu-z.html
use CPU-Z ID
to check the RAM
or use
https://www.crucial.com/
download the scanner to scan the RAM being used
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298694
You might need to enable or change your XMP profile in the BIOS
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298701
use CPU-Z ID
to check the RAM
or use
This is what I got for the CPU-Z- https://gyazo.com/d1d65236fb6e062dfc35b4526a17ca0d and https://gyazo.com/d4cc5b08bba7ea0816475db2a8bc34e6
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298714
Yup I definitely think I'm right now
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298719
ah ha looking at the second screenshot
you see the XMP mode with 1866MHz
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298735
By default most motherboards will default to the "safest" speeds that are pretty much guaranteed to work, so you can at least POST and set it higher at your own discretion.
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298765
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6298771
Went into BIOS this morning and swapped to XMP mode and this is what cpu-z says- https://gyazo.com/a717b52a2eb56bfd62556a65dc454ef6https://gyazo.com/8738c62825858b6eaa1d841d7454f3d5. So that was the problem, thanks for the help!
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6304932
No problem.  I've learned from experience with this myself :)
https://linustechtips.com/topic/469697-memory-speed-help/#findComment-6305031
