Network Adapter Driver problem, No internet - please help
Solved by SubTract,
Are you using ethernet or wireless?
Is it intergrated into the motherboard or a dedicated card?
You can go into device manager, Find the unknown device, Go to properties, Details tab, Change the dropdown box to hardware ID (might be device ID?) Copy and paste ID into google.
If its integrated into your motherboard you can go to the webpage for the motherboard and download the drivers from there.
