Hello, I have problem connecting on wireless in my parents house.
Problem is that windows 10 just say: cant connect to this netword. I tried the factory reset and it did got it to work,but however as soon as I set password he again cant connect. I tried more types or passwords,nothing work, it network is not open,laptop will not connect.
Other devices (phones,tablets) work without problem when password is set.
Router name:D link DI-624
Laptop : Lenovo g505s
Is there anything that I might be missing here,why does my windows  10 laptop have problem with password? (also worth to note that on other places my wifi works like a charm)
Thank you for support
https://linustechtips.com/topic/469282-nerwork-setup-problem/
D link DI-624
there's your problem...
those things are HORRENDOUS. they're underperforming, unstabile, dont support modern standards properly (even though the box says they do)
they're that bad i tossed mine in the bin, didnt even care about keeping it around for emergencies anymore.
https://linustechtips.com/topic/469282-nerwork-setup-problem/#findComment-6293694
Yeah,figured as mutch that 2004 lowend router is having problem with 2015OS, but still turning off the password when I want to connect is super annoying.
https://linustechtips.com/topic/469282-nerwork-setup-problem/#findComment-6293770
does the password happen to be WPA2PSK?
EDIT: i mean the way you set up your password, not the actual password.
https://linustechtips.com/topic/469282-nerwork-setup-problem/#findComment-6293778
I tried both WPA-PSK and WEP, same result, android devices connect without problem and windows laptop wont,I take down password and I connect without problem.
https://linustechtips.com/topic/469282-nerwork-setup-problem/#findComment-6293830
you're sure you're not typing the password wrong, right?
https://linustechtips.com/topic/469282-nerwork-setup-problem/#findComment-6293842
