Hello,
I am not sure if this is where this goes but I am toying around with a few build idea but failing at understanding if one is the way I should go for what I need. So to mesh with my learning style I think if I mention what I am looking for and planning to use the pc for and see what a few of you come up with I can align it with my thoughts and see where I stand. I am trying to build a gaming rig that serves a purpose that I think is different from what most gamers try to build. I play one game and usually one game only but I play it four times. What I mean by that is I play the same game in four separate but simultaneous instances with multiple accounts. That is right I am essentially multiboxing on one machine. The game I play is Eve Online and usually focus is on one or two of the account windows at one time with the others in the background or sitting still scouting not moving around needing to render new areas. I want to build this from scratch with newer ish tech. I was thinking something along the lines of the new z170 Skylake for its number crunching ability. I figured since I am not shoving everything I got into one window but spreading it out I would want something that could handle the multiple processes running at once. If this logic is flawed, please tell me now. For video cards, I was looking at either one or two to support two or four monitors respectively. The last time I truly built a PC the 2011 Ivy Bridge – E just came out (sadly I was too poor at the time to pick one up.). Any thoughts, sample builds, etc. would be highly appreciated and as for cost, I was trying to stay around $1,500 or less range (not counting monitors, keyboards, etc) just the tower.
o7
Thanks,
Aeternalis
Fly safe and Stay Shiny
https://linustechtips.com/topic/468209-build-help/
Hello,
I've not looked into multi-box set up needs, but wouldn't it be possible to just build like 3 additional PCs to run the other game instances? You could probably do a really neat build with some stacked ITX cases.
But ya if you can do it with just one strong PC that'd be better I suppose.
At that budget you might as well go X99
The Motherboard is overkiill, so maybe drop that a bit and get a nicer case, but it does have some nice features.
PCPartPicker part list: http://pcpartpicker.com/p/wdpPrH
Price breakdown by merchant: http://pcpartpicker.com/p/wdpPrH/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($378.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ Amazon)
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard  ($309.99 @ Amazon)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($83.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.33 @ OutletPC)
Video Card: Sapphire Radeon R9 Fury 4GB Tri-X Video Card  ($534.98 @ Newegg)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($39.98 @ Newegg)
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.89 @ OutletPC)
Total: $1519.14
Generated by PCPartPicker 2015-10-16 18:43 EDT-0400
It doesn't seem like EVE requires very strong hardware, so the multi PC set up might be better for ya depending on what you want to do.
https://linustechtips.com/topic/468209-build-help/#findComment-6283782
Total: $1519.14
http://pcpartpicker.com/p/dNcpcf
Almost completely different from yours but mine doesn't have an i7 as thats just overkill for what your going to be using it for as the i5 is plenty fast enough while the 980ti... almost the best graphics card available let me know what you think!
https://linustechtips.com/topic/468209-build-help/#findComment-6284249
If he were going to save money on components then I'd recommend getting a 4k display in the build
and a 980ti is faster, however you start to lose performance per dollar, and given his running multiple instances of the game, I don't know if having the faster memory dump on a Fury is going to help with that
https://linustechtips.com/topic/468209-build-help/#findComment-6284394
