Shortcut for mic
Go to solution Solved by Captain Matt,
Hello guys,
just wanted to ask if there is a way to create a shortcut on the keyboard to mute the mic? Since when im ingame its kinda dumb to tab out to teamspeak to press the mute button.
I just found a way with a programm but it would be better if there is  a nonprogramm way to do it. Im using Teamspeak only and a Roccat Isku if this matters
You can do it IN teamspeak! :)
>Settings
>Options
>Hotkeys
I like using F9 for mute mic, F10 for mute sound.
I use / and * on the numpad for OBS recording/start stop streaming so those could be options for you too.
Hello guys,
https://linustechtips.com/topic/467642-shortcut-for-mic/
Hello guys,
>Settings
>Options
>Hotkeys
https://linustechtips.com/topic/467642-shortcut-for-mic/#findComment-6274061
Why not use push to talk in TS?
EDIT: Follow your topics @Bonedog
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/467642-shortcut-for-mic/#findComment-6274062
Also convenient buttons for playing games and finger overlap is difficult in fast paced first person shooters.
Stinky foot boards would make a GREAT answer to this problem. To me (and I don't own one) they seem more like a productivity tool as well as a gaming tool! Also very cool for handicapped gamers.
https://linustechtips.com/topic/467642-shortcut-for-mic/#findComment-6275913
I have a mouse with an extra button that I macroed to F9. Works perfectly for push to talk.
https://linustechtips.com/topic/467642-shortcut-for-mic/#findComment-6275973
I'm not sure that would work for all grip styles... I use a RAT 7. I love it. The button layout could be SLIGHTLY better but I personally use a claw grip and assign the buttons I can reach to in-game things, so it would affect my grip if I were to clench my mouse on the harder to reach keys in order to tlak which would take away from my aim. Alternatively, placing the assignment on the more handy buttons would affect how easy it is for me to execute some actions in game.
https://linustechtips.com/topic/467642-shortcut-for-mic/#findComment-6276286
