I am thinking of creating a pc i am going to be using it for gaming and solidworks maybe a bit of animation. I will be using windows 10 with it and i cannot salvage any old parts. If someone could help me with the parts to make a solid futureproof machine it would be handy also if you are recommending me a case i would like one with a side window L.E.D's dont really matter. I only require internal component help and my budget would be 700 euros which is rougly 800 dollars i know a good cheap site to but the items i just dont know what to get Thanks!
https://linustechtips.com/topic/467101-components-help/
Your basically looking at getting an 4th gen CPU (4690 or less) & a 380 2GB version. Could always look at the 960.
To be honest your at the fine line of getting a good computer and having to give up on certain things to make your budget work, but at the same time not giving it the full whammy.
If you can stretch to 800 euro's or so you will pick up a very good system for what your wanting.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
https://linustechtips.com/topic/467101-components-help/#findComment-6267219
But i dont even know what parts to choose for my needs thats what i need help for
http://de.pcpartpicker.com/p/ng4QJx
200 over budget, but this gives you a good idea of what's recommended in general at the moment to get the most out of your money.
If you give me an idea of the actual programs your using and the games you want to play I'll amend this build to suit your needs and I can advise if going over budget a little bit would be helpful or if sticking to the original as planned is better.
https://linustechtips.com/topic/467101-components-help/#findComment-6267247
