Upgrading GPU, need low cost options
Solved by don_svetlio,
Just checked, since my vendor doesn't sell it, I guess I'll have to call about it, other vendors sell the GTX 950 for R2,999, which makes it the same price as a 960 from the discounted vendor.
This is true, did a check up on it, turns out a GTX 950 will get 1-10 frames better in a lot of games. If the prices are roughly the same, then I could look into that.
get the 270X - you mentione waiting for new stuff - the 950 doesn't support DX12 and will fall behind by anywhere from 10-20% in DX12 games. Get the 270X as it's cheap and powerful (will run any current game) and get a new system when you can ![]()
