Hey guys,
So simple question, when you "isolate" a fan with say a neoprene or rubber gasket or little rubber rings between the fan and the case/radiator, don't the screws touching the fan still transfer quite a lot of vibrations to the case anyway?
So if you want to completely isolate a fan would you actually have to isolate the fan from the case/rad as well as the screw?
Home is where the heart my desktop is.
https://linustechtips.com/topic/467001-isolating-vibrations-from-fans/
