Guys, i am new. I just wanna ask for a value gtx 960 build, for gaming and editing and streaming or video recording and some other stuff like that. I prefer nvidia to amd and also intel to amd.
I need cuda from 960 and i don't mind turning down the settings to medium and stuff. It can be around 700 to 800 USD.
Also, can you guys recommend a value mouse and keyboard? I would appreciate if someone can.
Thanks!
(sorry for bad english)
https://linustechtips.com/topic/466993-help-noobie/
Thanks!
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($232.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($175.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Total: $794.72
Generated by PCPartPicker 2015-10-14 06:53 EDT-0400
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265590
Here you go. Streaming will lag a bit, same as video editing. http://pcpartpicker.com/p/nwtyCJ
Xeon is needed. i5 won't handle it. I've got an i5 4690 and I can only record 720p. Getting a Xeon 1231v3 VERY soon.
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265599
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($82.88 @ OutletPC)
Case: Corsair 200R ATX Mid Tower Case  ($64.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($30.99 @ NCIX US)
Total: $791.04
Generated by PCPartPicker 2015-10-14 07:19 EDT-0400
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265702
Total: $794.72
can a b85 pro4 replace the h97 anniversary then, and btw, is western digital or seagate better?
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265796
Total: $794.72
This ^
the only i would change is the ram to a 1600mhz cas9, since the mobo doesnt support 1866mhz.
Other than that, 10/10 it will do for video editing and gaming, since xeon 1231 v3 is an i7 without the igpu(intel hd) at the price of an i5
The site has changed....
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265797
H97 is better has better features and doesn't require a Bois update as the b85 does.
The hard drives are similar
https://linustechtips.com/topic/466993-help-noobie/#findComment-6265816
