need a iso
Go to solution Solved by FunkyFeatures,
/r/microsoftsoftwareswap probably has a download for almost every windows sold on there.
if anyone has the windows 7 ultimate 64bit iso file i would greatly appreciate it i have a dell and my os crashed hard after the windows 10 update and i need to reinstall it .
you can inbox me if you need to .
i cant download it because of the digital river change and the windows version doesn't cover oem.
https://linustechtips.com/topic/466544-need-a-iso/
do you have a key? then get it directly from the website
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/466544-need-a-iso/#findComment-6260080
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/466544-need-a-iso/#findComment-6260096
oem keys are not supported by the iso downloader .ive tried every way to get it so far.
Torrent a non-cracked copy. That way it's legal to do.
I used to do this for builds I made for others. I'd download a copy onto a USB drive and then buy an OEM key from software swap to register the copy. Perfectly legal.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/466544-need-a-iso/#findComment-6260189
Thank man it worked perfectly other than my chrome is being a ass but thank you
Glad I could help you :)
https://linustechtips.com/topic/466544-need-a-iso/#findComment-6267237
