Disassembling Switch 810 top panel
Go to solution Solved by JordanMac,
you can pull it out without breaking it by bending the top panel, i removed mine to replace with mesh but it could have gone back in without a problem
Hi, I was just wondering whether there is a way to to disassemble and reassemble the top panel of the Switch 810 without damaging it, because I'm going to paint it and I'd like to just paint the frame without the grills that can be opened/closed. Has anyone done this before and if so, how? Thanks
https://linustechtips.com/topic/46650-disassembling-switch-810-top-panel/
this part?
or the front of the case?
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
this part?
That part in the picture.
Alright, thanks, that sounds fairly simple. Which way/direction did you bend it?
Haha, that's not what I meant ;) the top part consists of two individual parts, I want take out the inner.
ahhhh ok now  i understand :) usually companies glue the mesh on. see if it can pop off?
You can replace the top metal panel. Its not that hard to take it off. Once you see it, its kinda logical.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
