Hi,
I'm just curious, which CPU is better for rendering Intel or AMD? In softwares like in 3dmax or after effects... Which one gonna do it's job better i7 or AMD's 8 core cpu [don't remember the model name]?
Are there any benchmarks on the same system in those softwares?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/46623-which-cpu-is-better-for-rendering/
i7 still better at rendering because of superior single threaded performance with hyper threading
Well 8350 does it very well, but usually i7 outperform it.
The FX 8350 is on budget however the Core i7 will be better.
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
just to give you some idea and benchmark results
8350 is almost equal with 2600k in cinebench (not sure about 3dmax though)
http://www.anandtech.com/bench/product/287?vs=697
Yeah, as others have said the choice between Intel and AMD comes down to your budget. If you can only afford an 8350 and nothing more expensive, then get that over an Intel at the equivalent price. If you can afford to buy a more expensive Intel, surprise surprise it will perform better, hence the 'i7' will be faster (I say 'i7' because there are multiple different i7 models using multiple sockets and not all are equal even at similar price points).
