Do the fan on the graphics cards start up when you start the computer?
You could try and plug the monitor into the motherboard and install the graphics card driver and then try the graphics card again.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/46590-video-card-help/#findComment-615710
Make sure that your gpu is fully inserted into the PCI-E slot and you cannot see the gold on the connectors. Check that your monitor connections are properly inserted and make sure you set your monitor to the input you plugged it into (HDMI, DVI, VGA etc.) Try a different PCI-E slot if it doesn't work to see if your PCI-E slot is defective.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/46590-video-card-help/#findComment-617428
