I need some help in ordering a ring.
However I don't know my ring size sadly. I can't print a paper ( Because printer is a mental and won't print in black and white without cyan and yellow apparently !!!!)
The deadline is on tues and monday.
Any solution? I tried the 5 inch by 1/2 inch however its still pretty strange as the mm size exceeds most conversation charts I have seen.
Do you guys know any good conversation charts of inches into mm for ring sizes ? Or any other way to get a ring size quick?
from the 5 x 1/2 my finger sizes is 3 1/4. I can't find a rough estimate of ring size it just gives me diameter and circumference stuff...
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/465734-ring-size-help/
Go to a jeweler.
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
https://linustechtips.com/topic/465734-ring-size-help/#findComment-6249673
