I have a good computer with an Intel i5 4590, 1.5 TB hard drive, 4gb of ram (Which is bad) and a Nvidia N570GTX but when I boot up the computer some programmes open really slowly... Right click takes time to open and so does google chrome, even with all the start up options disabled... League of Legends, Team Fortress start up menu's also lag for some reason although my mac book pro 2012 doesn't... Why is this, and how do I fix this problem?
https://linustechtips.com/topic/465249-slow-start-up-issues-on-my-computer/
Did you use it frequently? If yes it might be because of you have too much file
DESKTOP PC :
  CPU :RYZEN 5 2600/ GPU :MSI Ventus OC GTX 1660 Ti/ RAM :Team Elite 2x8/ PSU :Corsair CX650M/ HDD :Toshiba 2TB/ SSD :Adata XPG M.2 SATA 265GB/ COOLER :Be Quite 2x140mm / MOBO :Asus TUF B450 Gaming
LAPTOP :
  CPU :i7-4710HQ/ GPU :GTX 860M/ RAM :8GB OEM/ HDD :1 TB
PERIPHERALS :
  MOUSE :LOGITECH G502/ HEADSET :HyperX Cloud Alpha/ KEYBOARD :Logitech G Pro
POSSIBLE PC BUILD :
  PC PART LINK
If you open task manager after boot and keep an eye on the performance tab is it CPU or Disk that is high, might be worth running a general maint run (i.e. defrag/ccleaner etc) first.
CPU: Intel i7-4790K | GPU: Asus Strix 2080 Super OC | COOLER:Corsair H110i GT | MOBO: Asus Maximus VII Hero | RAM: 4x4GB Corsair Vengeance Pro 2133mhz PSU: Corsair RM 1000 | CASE: Corsair C70 | MOUSE: Corsair M95 KEYBOARD: Corsair K70 RGB SSD: Samsung 256GBx2 Raid0 | OS: Windows 10 | DISPLAY: Dell S3220dgf
It might be your hdd . What speed is it ? If its 7200 rpm, you should be ok.
Sometimes drives can get cloged up , so try defragmenting it and using a program like ccleaner on it .
I personnaly run my os on a hard drive and it can get slow after some use .
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Your hard drive might be dying . check it for errors and do a speed test on it with someting like crystal disk mark and compare it to the known speeds of that drive.
another sign : is your hdd making a lot of noise ?
