I know this is kinda dumb question, but what parts do i need in water cooling? i found a water cooling in xspc the one with 270 reservoirs (Cylindrical) i don't really know what's "fitting" "tubing" and pumps. can you give me some specific partlist in XSPC products that i need. My system is composed of 5820k, Asus X99 Deluxe, and i have a GPU which is Asus GTX 980Ti strix. i built my own pc desk case, inspired by red harbinger crossdesk in geforce garage.
A BIG THANKS for those who will help me, Newbie in water cooling system
PS. this is the one I'm planning to buy, but not sure if compatible, and pros and cons. your help is HIGHLY appreciated.
http://www.xs-pc.com/watercooling-kits/raystorm-d5-photon-ax360-watercooling-kit
https://linustechtips.com/topic/464007-xspc-water-cooling/
I know this is kinda dumb question, but what parts do i need in water cooling? i found a water cooling in xspc the one with 270 reservoirs (Cylindrical) i don't really know what's "fitting" "tubing" and pumps. can you give me some specific partlist in XSPC products that i need. My system is compose of 5820k, Asus X99 Deluxe, and i have a GPU which is Asus GTX 980Ti strix. i built my own pc desk case, inspired by red harbinger crossdesk in geforce garage.
im going that to. What you need are the waterblocks for cpu and gpu. barbed fittings for soft tubes on the waterblocks. compression fittings on the actual tubing and the compression fitting is screwed into the barbed one. repeat process for all parts
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/464007-xspc-water-cooling/#findComment-6227616
-SNIP-
Welcome to the Forums!
That's a good start with the kit you have there basically the thing you need to add in is two more fittings and the GPU waterblock which the fittings are 7/16" ID, 5/8" OD fitting:
http://www.xs-pc.com/hose-fittings/g14-to-716-id-58-od-compression-fitting-black-chrome
https://linustechtips.com/topic/464007-xspc-water-cooling/#findComment-6227627
I have those, the 1/2in version, they look awesome. well, two of them anyway...
https://linustechtips.com/topic/464007-xspc-water-cooling/#findComment-6227637
what waterblock are you using? for the gpu
https://linustechtips.com/topic/464007-xspc-water-cooling/#findComment-6227649
