Surge Protectors
Well I have multiple access points that will be POE using POE injectors (not sure on the wattage). The switch uses 58 W under max load, the router uses something like 15 W.
As for the computer itself, it will be being used as a server so the only thing that will need to be powered is the computer itself (no monitors, keyboards, or anything like that). It probably pulls about 250 W.
Those are the only items that will be utilizing a UPS. That way it allows the network to stay up when the power is down and enough time to power down and save stuff on the server.
Yeah that UPS will give you more than enough overhead and then some for everything.
If you want a smart UPS since you are running a server it can safety shutdown the PC if the battery level runs down too low or a certain time from an extended power outage.
