Hello! i have a spare rig here with a corsair h100i but i only have 3 of the thumb screws to mount the cooler onto the cpu, would 3 be ok or would it be dangerous?
Many thanks - New forum guy
I would try and find a nut or something that fits in order to tighten it down, - it wouldnt be dangers with 3 , but you will have to monitor the temps to make sure tere is no issue, really it needs to be mounted properly though
https://linustechtips.com/topic/463594-please-help-h100i/#findComment-6222184
I wouldn't you don't want to risk overheating your CPU. From my experience the H100i isn't that good with the 4 screws anyway, I had to put o-rings behind my backplate to actually make it contact completely.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/463594-please-help-h100i/#findComment-6222215
Thank you for the speedy replies guys! ill use the 3 and order some new ones, i couldnt find any on corsairs site unless im a 100% idiot and didnt see it >.<
You can probably take one of the bolts you currently have to a hardware store. they can match it up and probably have one exactly like it in stock.
Can verify as i have worked in a hardware store and did this a million times.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/463594-please-help-h100i/#findComment-6222238
