So so i convinced a buddy of my to build a pc an put down the console, as a help i have him my g3258 chip, which will be plenty to start him off... well with out letting me know he got a node 202 from Fractal Design, good case, problem is he wants to use the m.2 drive from his laptop as storage. So.... i need help finding the following all on 1 board:
Itx size
M.2 ssd slot
Built in wifi (optional)
Socket 1150 (obviously)
CHEAPEST YOU CAN FIND
Doesnt matter if its h81,h87,z87,h97,or z97... just has to have a working sata m.2 slot (see attached picture
post-229763-0-69597600-1444176803_thumb.
https://linustechtips.com/topic/462728-need-help-finding-a-specific-mb/
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
Itx size
M.2 ssd slot
http://pcpartpicker.com/part/asrock-motherboard-z97eitxac
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
yeah but why buy a $250 mobo for a $60 cpu................
bad enough what he wants is gonna be 120...
because upgradability
Solitaire.
Yea that asrock is the best i was able to find as well, i was hoping for like 60-80 bucks, and its still a z97 so ill get a small overclock out of it, probably 4.0 just by changing the multipler. Only reason hes going cheap now is to try pc gaming... if he likes it then he will invest more down the road, he just doesnt want to spend 1000 and then not use it,
The motherboard is like 120$ not 250....
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
the asrock is...... the maximus isnt
Asus impact is for "bing" factor. Asrock Z97E-itx will overclock just fine, with Wi-fi and M.2 slot.
hence the "if you can afford it"
Solitaire.
