Hello everyone,
In a couple of weeks time i will be modding my desk meaning adding a monitor stand plus add some led lights to the desk.
I am going to be using these lights:
http://www.amazon.co.uk/Tingkam%C2%AE-Waterproof-5050RGB-Lighting-lighting/dp/B00H7T7XA2/ref=sr_1_4?ie=UTF8&qid=1443942580&sr=8-4&keywords=led+strip
Now I want to use only one of the packs and not buy 2 of them meaning two seperate controllers.
I want to use the whole 5m and one controller, you will see what I mean
Are there like connects for led lights so I can connect two strips together?
https://linustechtips.com/topic/462019-led-light-connectors/
Eeh, by gum.
ThrustJetViperPowerMustang: FX-6100 @4.4GHz (Stock Cooler) / 4x4GB Hyperam @ 1333MHz / OCZ Octane 250GB SSD / Asus HD6670 2GDDR3 / Asus M5A78LM-USB3
https://linustechtips.com/topic/462019-led-light-connectors/#findComment-6200211
What I would do is to get a long LED strip. Measure the dimensions of the desk, then once you have the total length, buy the LED strip that fits the most. After that, get a 12v DC converter, to go from the 12v output the LED has to a molex connector. You can use this to power the whole strip.
https://linustechtips.com/topic/462019-led-light-connectors/#findComment-6200218
Hello everyone,
You'd need to solder them together and it really isn't hard at all.  In addition to that you'd need to use electrical tape to keep them connected.  Also not to be offensive but I kind of smiled when I saw the MS paint because that's how I planned out my Rpi server build.
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/462019-led-light-connectors/#findComment-6200227
This video is for a computer but it is the same principle.
https://www.youtube.com/watch?v=t3LjOEyc218
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/462019-led-light-connectors/#findComment-6200257
