Hi guys, i'm looking for a over-ear headphones for a price about 250$.
There are some stuff to mind though.
First of all, it's important that they look good, and i know that's very subjective, but just think about it before you suggest something square xD.
Secondly, ofc they need to sound great, both for music listening and for just plugging into at computer and watch a films.
The build quality is important too, i really don't want something that's all plastic-like and starts falling apart after two months of use.
It doesn't matter whether its a has a jack stick or a mini-jack stick i'll just convert that into what i need.
THIS ISN'T A HEADPHONES FOR GAMING.
I've been looking at the AKG K550 but the wire can't be removed, and with me experience with headphones that really something that breaks pretty fast after some ware and tare.
I know i'm a bit picky, but i really want to find the perfect pare, and since i cant afford buying all of the headphones in the world i turn to you guys. Hope you can help me, that very appreciated.
TL;DR The best headphones for 250$.
https://linustechtips.com/topic/461957-need-help-finding-the-perfect-headset/
Headsets are headphones with a mic usually.
You're looking for headphones.
Are you looking for open or closed back? And what type of music?
Okay thank you, i just edited my post for clarity. (can't seem to edit the title though)
The music will mostly just be a mixture of Pop and R'nB
i'm looking for at open back.
I think the Fidelio X2 is a perfect fit, though it's about $290.
