Mastercase Pro 5
Solved by TheCaptain53,
cheers
The MasterCase Pro 5 supports a 40mm thick rad at the top (fans not included). If you have the base MasterCase 5, you would not be able to fit an AIO on the top. You can also officially fit a 280mm in the front, but with the hole in the basement, I reckon a 420mm could be squeezed in there if the basement hard drive cage was removed.
