You need a backplate for the GPU block
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/461303-water-cooling/#findComment-6190158
What if he doesn't want to watercool the gpu?
I would avoid red coolant, because of the permanent coloring it does on the components.
He has a gpu block in the sheet so I think he does. Backplate is optional but highly recommended. If you already have red tubes than using red coolant is a bit overkill imho
You might also want to think about getting atleast 2l of coolant. 1l might not cut it and its always nice to have when you need it.
https://linustechtips.com/topic/461303-water-cooling/#findComment-6190341
