Inside a CPU, oscillator create spefic repetive signals that run thru the cpu. The time inbetween two oscillator is called clockspeed.
Quetion 1: Where is the oscillator located. Is it a circuit in the cpu die or in each transactor. Personaly I am assured that it is in the die itself. (Part2)Is the clcok cycle when each signals goes thru each transactor oscillator, where and how many oscalartors are their.
Quetion 2: The signal travels transactor to transactor and is usally bits of data?
Anyway correct me if I am wrong. I think I have a good idea about this.
I will keep releasing new quetions here now and them so come back to anwser at your earliest convince so that it can help me and anyone else who follows.
Thank You in Advance.
I have a pretty good idea abou it thoughty
To love is to risk not being loved in return. To hope is to risk pain. To try is to risk failure, but risk must be taken because the greatest hazard in life is to risk nothing.
https://linustechtips.com/topic/46068-general-adv-cpu-queions/
Don't you mean transistor?
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607126
yeah sorry for the miss spell I was using a different layout keyboard.
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607140
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607148
My only question is how many oscillator are their and where are they located.
Where is the microchip "Clock" located? on the die?
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607172
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607213
There's one oscillator per die.
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607225
Thank You very Much.
And It basicly sees to how fast the speed in-between one oscillator, thru the cpu and back into the oscillator
 is. The circuit :Clcok: and :Multiplier: both oscillator determining the speed and multiplying it
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-607239
Now that I know more, wront unless if you consider the multiplier which i belibe is on the mobo. Even is music waves, osilcators are used to produces wave freq
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-644762
https://linustechtips.com/topic/46068-general-adv-cpu-queions/#findComment-644814
