You're using this Widescreen Fixer correct?: https://www.widescreenfixer.org/
If yes, then check your AW's update version, Widescreen Fixer supports up to: v1.20.1374051.30 for multiplayer. If AW updated it might have broken Widescreen Fixer until the person updates the program, if the game updated then you should email the person behind Widescreen Fixer and tell him/her as he/she might not be aware there is an update for the game, email him/her here: d.rudie@gmail.com
I don't have any alternatives to suggest, sorry.
