Anyway I would get an AMD for Crossfire support.
CF and SLI work fine for both Intel and AMD.
If you meant Hybrid CF, it at its best is still worse than a single 260x let alone a 970.
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6174431
I mean so there isn't clashing drivers if he wants the APU to power a display in a multi display setup.
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6174469
intel
(R 15 ooo for intel build)
The build i think i whant there are 2GPU's I want one of the i just think te GTX970 is overkill for playing games at 1080p at 60fps on ultar.
 or
(R 13 000 for AMD buil)
Her is also 2GPU I want I just think the 8GB is overkill on the build for games at 1080p 60fps on ultra..
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6174677
There's no such thing as overkill=-)
Higher frame rate over higher resolution.
CPU-i5 4690k -GPU-MSI 970 sli -Mobo-MSI g45 gaming -Memory-16gb crucial ballistix -PSU- EVGA 80+ gold g2 850w -Case- corsair 200r
Monitors- Acer XB240H, Asus ROG Swift, Dell P2815Q 2160p  -Keyboard- Corsair k70 RGB -Mouse- Corsair M65 -Mouse Pad- Glorious Extended Pad -Headphone- BeyerDynamic DT990 250ohm, Senheiser HD 518, Fiio E10k
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6174745
There shouldn't be any clashing drivers.
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6177742
Yes.
Lol the fuck... Did I dream we were in 2015 and not 2011?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6177752
yes
and why A10 and not fx 8370e ctc.
Cpu: Intel i7-5820k at 4.6 Ghz // Motherboard: Asus X99 Pro // Ram: 32gb of Crucial Balistix at 2400 Mhz // Gpu: GTX 1080 Founders Edtion // SSD: Samsung 850 evo 250gb, Samsung 950 pro 256 gb, // Cooler: Cooler Master ml240r // Case: NZXT h500i
https://linustechtips.com/topic/460074-over-kill-or-not/#findComment-6180803
