Hello, I am gonna be building a computer soon, so I would like some gracious help.
http://pcpartpicker.com/p/ZhvHmG
This is a build for light video editing, live streaming on youtube, gaming, coding, and schoolwork.
---I am an NVIDIA fanboy, so I will not get an AMD 390 card
I need help with what surge protector(s) I should get for the following things:
-Computer (750watt psu, will overclock)
-Xbox one
-monitor, will be getting another one in about 3 months
-Leds
-Router
TOTAL OUTLETS NEEDED:  6, maybe prefer 8 for other uses.
Thanks in advance.
https://linustechtips.com/topic/459408-first-build/
-Xbox one
-Leds
-Router
Thanks in advance.
Get a 390, Mr. Thick Skull.
EDIT: Fix your link (you put a space after it). ​http://pcpartpicker.com/p/ZhvHmG
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/459408-first-build/#findComment-6165025
-Xbox one
-Leds
-Router
Thanks in advance.
your link goes to nothing  Edit: srry he fixed it
https://linustechtips.com/topic/459408-first-build/#findComment-6165033
Read my post, I fixed it for him. http://pcpartpicker.com/p/ZhvHmG He added a space after the URL.
https://linustechtips.com/topic/459408-first-build/#findComment-6165036
I do not care if you are a fanboy or not, if you are gonna get a GPU that is worse just because you do not like a company, or think one company is better over the other. That does not go in my book. I will still reccodmend a R9 390 MSI or Sapphire. Maybe if you gave a valid reason WHY but nope. A BeQuiet! Pure Rock is also better then a 212 Evo. Get a 250GB Samsung 850 Evo, not a 128GB 850 Pro. You also do not need thermal paste.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/459408-first-build/#findComment-6165041
-Xbox one
-Leds
-Router
Thanks in advance.
yes i know now i corrected my error
https://linustechtips.com/topic/459408-first-build/#findComment-6165062
fixed
*whispers* Get a 390 *whispers*
https://linustechtips.com/topic/459408-first-build/#findComment-6165064
-Xbox one
-Leds
-Router
Thanks in advance.
What games will you be running? And what will you be doing on here?
Numbre
https://linustechtips.com/topic/459408-first-build/#findComment-6165091
H1z1, Ark, Rocket League, and lots of others. I will livestream the games with OBS then take that footage and make separate videos from that livestream. I will also do light coding
Your card is a good choice. But AMD can fulfill your needs (and save you money).
Numbre
https://linustechtips.com/topic/459408-first-build/#findComment-6165120
