Ok so i'm forced into building a new PC for school ASAP. I really wanted to wait to see what AMD and INTEL were going to come out with next year in terms of new cpus. School has cut that plan up, shredded it, and then thrown it in the incinerator. I need a PC capable of running around 3 Virtual machines of windows 7, 8/8. and 10. Minimum 8GB of RAM with recommended 16GB. I also want to be able to do some gaming when i'm not studying but my HD7770 will suffice for a good while now. My budget is maxed at $1000 but i'd prefer to stay well under that. Also I want this thing to last for several years to come in terms of CPU and RAM. I'm not spending over $700 of my banks money for a machine that will only last me till next year. Any Ideas?
Adding one thing I forgot: I live in Canada so prices need to be in $CAD.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/458693-first-modern-pc-build-help/
You can probably start with this.
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  ($294.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($62.89 @ OutletPC)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  ($49.99 @ Newegg)
Total: $570.74
Generated by PCPartPicker 2015-09-29 19:30 EDT-0400
Something like this perhaps? The Xeon offers better value for money than the 4790.
I do recommend a GPU upgrade some time soon though.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard  ($69.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($74.99 @ Newegg)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive  ($144.99 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($116.91 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Total: $859.64
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Total: $859.64
gpu?
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
gpu?
Did you even read the post?
$628, add any GPU you want:
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($51.98 @ Newegg)
Storage: OCZ Trion 100 240GB 2.5" Solid State Drive  ($68.00 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($76.16 @ Amazon)
Total: $617.61
Generated by PCPartPicker 2015-09-29 19:56 EDT-0400
I could shave another $50 off of this (with no performance loss), but I liked the white, blue and black colours.  :)  Also, the CPU cooler is for quiet operation.  Stock cooling would do just fine.
$561:
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($33.99 @ SuperBiiz)
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)  <Front Intake
Total: $551.07
Generated by PCPartPicker 2015-09-29 20:00 EDT-0400
So what the logic of going Xeon E3-1231 V3 instead of the i7 4790 other then price to performance? Also what about a large SSD instead of a smaller one and then a large HDD later or vise versa?
RAINBOWS!!!
Sorry for the late response.
The Xeon is like having an i7 4770 (non-K), except that it does not have an iGPU.  It is mainly to save money while benefiting from the hyperthreading.  For gaming, it does as well as the i3/i5/i7s at the same clock.
120GB is not much.  With 240GB+ you can actually install games on it and not have to worry as much about filling it up.  You can always add mass storage later.  I run my PC without a mechanical drive.  It is quieter and cooler.
Ok so here's what I came up with after the advice you guys gave me. What do you think?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($432.78 @ DirectCanada)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($73.99 @ Newegg Canada)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($100.50 @ Amazon Canada)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Drive  ($99.98 @ DirectCanada)
Case: Raidmax ATX-402WB ATX Mid Tower Case  ($49.99 @ Newegg Canada)
Case Fan: Thermaltake CL-F011-PL12BL-A 41.0 CFM 120mm  Fan  ($6.05 @ DirectCanada)
Total: $819.32
Generated by PCPartPicker 2015-09-30 10:53 EDT-0400
All prices in $CAD
RAINBOWS!!!
OR What about this?
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($469.99 @ Memory Express)
Motherboard: Gigabyte GA-B150M-D3H DDR3 Micro ATX LGA1151 Motherboard  ($107.97 @ Newegg Canada)
Storage: Corsair Force LS 240GB 2.5" Solid State Drive  ($88.88 @ Canada Computers)
Case: Cougar Spike MicroATX Mini Tower Case  ($49.99 @ NCIX)
Total: $896.36
Generated by PCPartPicker 2015-09-30 13:32 EDT-0400
RAINBOWS!!!
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($432.78 @ DirectCanada)  <<<This is a K-Series CPU, you have an H97 motherboard next...
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($73.99 @ Newegg Canada) <<<You should have a Z-Series motherboard
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.98 @ NCIX) <<<I hope you don't plan to EVER add a GPU
Total: $819.32
All prices in $CAD
I'll refrain from picking on the next build you have... There are mistakes in your builds, some big ones.
$815 before taxes:
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($339.98 @ shopRBC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.98 @ NCIX)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($104.95 @ NCIX)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($108.39 @ Vuugo)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ NCIX) <<This is more power than you will probably need, but the price is right and component quality is very good.
Total: $760.38
Generated by PCPartPicker 2015-09-30 17:24 EDT-0400
$863 if you need an i7 for reasons you don't understand =)
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  ($388.49 @ DirectCanada)  <<Notice this is NOT a K-Series?
Total: $808.89
Generated by PCPartPicker 2015-09-30 17:34 EDT-0400
Price goes up to $920 if you want easy overclocking on the CPU:
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($82.99 @ NCIX)
Total: $861.19
Generated by PCPartPicker 2015-09-30 17:38 EDT-0400
Total: $819.32
All prices in $CAD
You will need a z97 mobo in order to overclock. Also change that crappy psu
OR What about this?
Total: $896.36
You will need a z170 mobo in order to overclock and ddr4. Same as before goes for the psu
The site has changed....
So how about this: Yes i know the psu is over kill but its something that will hopefully last through a few builds in the future.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($329.99 @ Newegg Canada)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($100.04 @ Amazon Canada)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($49.00 @ shopRBC)
Total: $717.94
Generated by PCPartPicker 2015-10-01 11:12 EDT-0400
RAINBOWS!!!
Total: $717.94
That looks fine.
The Corsair Force LS is great on sequential read/write (large files), but is it sluggish with 4K random R/W (small files) speeds.  It is still really fast, when compared to HDDs.  Corsair customer service is really good.  I have a Force 3, and it has been replaced by Corsair with no issues to do so.
http://www.anandtech.com/show/7337/corsair-force-ls-240gb-review
i added a 650w gold psu in case you want to get a new gpu that requires 600+w or has a pull of 250w at the minimum. this should give you enough headroom for an overclock on the gpu.
if you want to make it less expensive, change the psu to the EVGA 110-B2-0750-VR or the Antec HCG-620M
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($71.98 @ Newegg Canada)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($99.98 @ NCIX)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1600 Memory  ($100.99 @ NCIX)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($129.75 @ shopRBC)
Case: Cooler Master N400 ATX Mid Tower Case  ($67.50 @ Vuugo)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($115.76 @ DirectCanada)
Total: $915.95
Generated by PCPartPicker 2015-10-01 16:06 EDT-0400
BigDay
Total: $915.95
Your build is compatible, but it is over $900.  The previous build was under $800.  There is no performance benefit between the two build, other than the SSD.  The EVO is faster than the Corsair LS.
Is there a reason you picked a $70 cooler for that Xeon?  The Xeon is fine on stock cooling, it is just louder.
he could go with the 212 evo
i forgot about that one
BigDay
