1. Budget & Location
2500 U.S$
2. Aim
It will mostly be used for gaming (mmo and fps) but it will also be used for making videos and editing them(YouTube). It will also be used for designing(Auto-Cadd and Solid-Works)
3. Monitors
I plan on starting with 2 monitors but will be getting 3 asap. Resolution 1920X1080
4. Peripherals
planing on getting Windows 10, a Razer Deathadded Chroma with a BlackWidow chroma
http://pcpartpicker.com/p/jNfqZL
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video card: NVIDIA GeForce GTX 970 4GB Video Card
Case:NZXT Phantom 410 (Black) ATX Mid Tower Case
Power Supply: Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply
Monitor: Asus VG248QE 144Hz 24.0" Monitor
https://linustechtips.com/topic/458599-first-build/
Get a 390 if you want a bit more performance for the same cost but else it's solid
EDIT: The VRAM will help a lot with more monitors for surround gaming - 3.5GB will be an issue if you wish to game on all 3
https://linustechtips.com/topic/458599-first-build/#findComment-6154297
Please don't get Razer products. The build quality is sub-par for the price you pay
Edit: Wouldn't an i7 or a Xeon make more sense for editing workloads?
Case Corsair Air 540 CPU AMD Ryzen 5 1600 GPU EVGA GeForce GTX 1080 SC2 iCX Motherboard Asus X370-F Memory G.Skill Flare X 16GB (2x8) 2400MHz Display Asus VG248QE Storage Samsung 960 Pro 512GB - Intel 730 Series 480GB SSD - 1TB Seagate Barracuda - 1TB WD Blue OS MS X Pro Peripherals Corsair K70 RGB Rapidfire -  Razer DeathAdder 2013
Case 15.4" Mid 2012 MacBook Pro CPU Intel Core i7-3720QM GPU Nvidia GT650M Memory Crucial 16GB (2x8GB) DDR3 1600MHz Display 1680x1050 AntiGlare Display Storage 1TB 5400RPM or Intel 730 Series 480GB SSD OS OS X Yosemite (Maybe El Capitan?) - BootCamp MS X Pro Peripherals Razer Blackwidow Ultimate 2014 -  Razer DeathAdder 2013 - Mionix Naos 7000 - Logitech K120 - Razer Tartarus Keypad
https://linustechtips.com/topic/458599-first-build/#findComment-6154307
Maybe some 1866 speed ram for that board, you need that few more nanoseconds of speed for the same price.
Also when you get that monitor please review i am thinking of getting it.
I don't actually give useful information, hopefully I just  say something funny.
https://linustechtips.com/topic/458599-first-build/#findComment-6154331
then what would you recommenced
Literally any of the other peripheral companies that make 'gaming' stuffs. I think the only Razer product I can actively recommend is the DeathAdder 2013 but even that has its problems and I don't like recommending it.
https://linustechtips.com/topic/458599-first-build/#findComment-6154346
youmay want to go to 16 gigs of ram since you say you will also be editing video the extra ram will help
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/458599-first-build/#findComment-6154361
2500 U.S$
2. Aim
3. Monitors
4. Peripherals
Check this.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/458599-first-build/#findComment-6154416
Check this.
Asus and AMD - is your name Michael Bay?
EDIT: Sapphire or MSI for the 390 :)
https://linustechtips.com/topic/458599-first-build/#findComment-6154428
this will probably serve you a bit better, better cpu,gpu, psu, aio,, wifi on your mobo(much better than the cheap wifi cards)
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($317.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: ASRock Z97 Extreme6/ac ATX LGA1150 Motherboard  ($234.99 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.45 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($94.89 @ OutletPC)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($244.51 @ Amazon)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.99 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($59.99 @ Amazon)
Other: Dxracer chair ($289.00)
Other: Desk ($140.00)
Total: $2375.64
Generated by PCPartPicker 2015-09-29 16:53 EDT-0400
https://linustechtips.com/topic/458599-first-build/#findComment-6154450
Try this. I almost made in the budget...almost.
PCPartPicker part list: http://pcpartpicker.com/p/NWKWQ7
Price breakdown by merchant: http://pcpartpicker.com/p/NWKWQ7/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($364.99 @ B&H)
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($149.99 @ Amazon)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2666 Memory  ($107.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.00 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($399.99 @ Amazon)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($104.99 @ NCIX US)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ NCIX US)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.95 @ B&H)
Total: $2505.18
Generated by PCPartPicker 2015-09-29 17:00 EDT-0400
Edit: Looking at it now I almost ended up with a white/black theme. Except MSI doesn't know what they're doing and has poor color coordination with their MoBos and GPUs. So almosts with me today.
https://linustechtips.com/topic/458599-first-build/#findComment-6154524
At present you can't go wrong with an ASUS MOBO and the cooler is really working for the 390.
I try to stay away from MSI and Galax because of their aftermarket support like if you remove the cooler you void the warranty and their drivers are a bit wonky in the past, z97 and x99 seems to be stable though.
https://linustechtips.com/topic/458599-first-build/#findComment-6155922
AiB don't make drivers >.>
The Asus 390 sits at 80-85*C ._.
Sapphire one sits at 74*C
MSI sits at 75*C
Galax are 2nd only to EVGA
https://linustechtips.com/topic/458599-first-build/#findComment-6155936
--gone---
^ is in your opinion or for real because when i had my Galaxy card i found out differently. Galax, formerly Galaxy, has great GPUs but seriously poor support, and they are, or were not upfront with their warranty policy in the past. I have since moved to EVGA but if i had to purchase a GPU now, i would get an AMD, from ASUS but i have never had any experience with Sapphire even though they seem to be popular for AMD.
https://linustechtips.com/topic/458599-first-build/#findComment-6156210
As a owner of an Asus R9 280 I tell you. Look another way - Sapphire Dual-X card is a lot cooler and more reliable - Sapphire's support is also better. Their Vapor-X cards are better than almost all other coolers on the market - probably only EVGA KingPin and Lightning from MSI can outclass them. Even then it's a hard one
https://linustechtips.com/topic/458599-first-build/#findComment-6156258
I don't know how to navigate this forum very well so i hope you don't mind me asking my question here. I'm on a limited budget, i want to build a PC for 3D modeling and casual gaming. What do you guys think of these parts I've selected? Remember i'm a noob so i could have made a lot of mistakes in picking parts that i'm sure you guys can educate me on. Thanks in advance!
$_1.JPG?set_id=880000500F
Quantity:
$3.95
Economy (3 business days)
USPS Parcel Select
+ $7.00
$_12.JPG?set_id=880000500F
Quantity:
$39.79
$59.79
Economy (4 business days)
Economy Shipping
+ $7.99
$(KGrHqEOKpIFIBc2)W+CBS!-UNNRvQ~~60_12.J
Quantity:
$49.99
Economy Shipping
eBay FAST'N FREE
FREE
Quantity:
$82.80
Standard (5 business days)
UPS Ground
FREE
Quantity:
$64.49
USPS First Class Package
FREE
$_1.JPG?set_id=8800005007
Condition: New
Add 1 more to qualify
Buy 1, get 1 at 10% off
Quantity:
$4.45
Economy (5 business days)
Economy Shipping
FREE
Quantity:
$39.99
Expedited (3 business days)
USPS Priority Mail
eBay FAST'N FREE
FREE
Condition: New
Extra 5% off when you buy 2+
Quantity:
$11.73
Standard Int'l Shipping(9-21 business days)
ePacket delivery from Hong Kong
+ $1.29
Condition: New
Quantity:
$23.99
FREE
https://linustechtips.com/topic/458599-first-build/#findComment-6209915
@Layke
So that is a $400 budget?
You could try something like this:
$430
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
<<this is much faster than the FX 4XXX CPU.  It also has graphics on the CPU that are just as good as the Nvidia GT640
Motherboard: ASRock B150M-HDV ATX LGA1151 Motherboard  ($69.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($53.99 @ Newegg)
Storage: Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($38.90 @ Amazon)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($34.99 @ SuperBiiz)
Power Supply: Antec Basiq 350W ATX Power Supply  ($25.98 @ OutletPC)
<<This is a temporary power supply until you save enough money for a good GPU
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)  <<Front intake
Total: $422.82
Generated by PCPartPicker 2015-10-06 23:08 EDT-0400
https://linustechtips.com/topic/458599-first-build/#findComment-6211124
So if i were to buy a better GPU at a later date...
1. all i would have to do is upgrade the power supply, right? So would it be worth it to buck up and buy a better power supply now?
2. Also I'm interested to get your input on the one 8 gig stick vs two 4 gig.
3. is there a way to save on the CPU at all? If not then i could make it work
4. should i get a cheap optical disk drive for installing drivers and such?
Thanks your a big help
https://linustechtips.com/topic/458599-first-build/#findComment-6211463
1.  Yes and no.  The power supply I selected is fine for the PC without a GPU.  With a GPU I would recommend a good power supply... something like these:
Non-Modular
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
http://pcpartpicker.com/part/xfx-power-supply-pro650wp1650snlb9
http://pcpartpicker.com/part/xfx-power-supply-pro750wp1750snlb9
http://pcpartpicker.com/part/xfx-power-supply-pro850wp1850snlb9
Modular (full and semi)
http://pcpartpicker.com/part/evga-power-supply-220gs0550v1
http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm
http://pcpartpicker.com/part/xfx-power-supply-p1550bbefx
http://pcpartpicker.com/part/rosewill-power-supply-capstoneg550
http://pcpartpicker.com/part/evga-power-supply-220gs0650v1
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
http://pcpartpicker.com/part/rosewill-power-supply-capstoneg750
http://pcpartpicker.com/part/antec-power-supply-hcg850m
http://pcpartpicker.com/part/evga-power-supply-110b20850v1
2.  The 8GB stick was because of the motherboard.  It only has two DIMM slots.  Grabbing 8GB now leaves room to add another for a total of 16GB.
3.  I would push for the Skylake i5 because of the better iGPU.  You can save a bit going Haswell (i5 4460), but the graphics are not as strong.  I guess it depends on when you plan on adding a GPU.
4.  You do not need an optical drive, unless you need it.  Windows can easily be installed using a USB stick.
You are welcome.
Haswell build:
$430
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($175.88 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($67.98 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($36.00 @ Newegg)
Power Supply: Rosewill 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $427.72
Generated by PCPartPicker 2015-10-07 00:23 EDT-0400
https://linustechtips.com/topic/458599-first-build/#findComment-6211646
