Integrated realtek vs wired network adapter
You mean use a PCI NIC instead of your mobos built in one?
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
I was wondering if it is better to buy a wired network adapter or to stay with the one who's integrated with the motherboard (Realtek adapter) ?
Do you need more network speed?
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
If your integrated is max 100Mbps, and you have faster than 100Mbps internet, or, plan on streaming from or backing up to other local network devices you may want to upgrade to a 1Gbps PCI-e NIC. This also requires that your router/switch is also 1Gbps compatible.
If you integrated is max 1Gbps, there is no point in going with another PCI-e NIC. The only way you will get anything "faster" is if you have specialized networking gear and specialized other computers on your network.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
