Ethernet wall wiring
Solved by W-L,
We want a secondary router/switch mostly because I have two pc's that needs ethernet cable and my panents got one, else we got wireless.
Ok then that would be your best solution, as said the secondary router needs to be setup in bridge mode the suffice that. You need to directly connect to the secondary router from your PC to setup the unit and specify it's IP address.
This is a an example on how to do it:
