Something like this, but this won't work in C#
int main(){    while(1){        printf("Hello, what is your name?");         string name = getline();         printf("How old are you %s?\n", name);         int age = getint();         printf("In what month were you born?\n");         int month = 0;         while(month <1 || month >12) {            month = getint();             if(month < 1 || month > 12)                printf("That month is not valid)         }        age = 2015-age;         printf("So you were born in %d\n", age);         return 0; }
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/457610-need-help-with-c/#findComment-6140967
namespace derpaderp talks back
class Program
static void Main(string[] args)
// Variable for the value "name"
string name;
// Console asks for a name
Console.WriteLine("Hello! I am derpaderp. What is your name?");
// Holds the value
name = Console.ReadLine();
// Displays the response
Console.WriteLine("Hi, {0}! I'm glad your name isn't as dumb as mine!", name);
https://linustechtips.com/topic/457610-need-help-with-c/#findComment-6140997
That's because it's not there. For some reason people like to suggest codecademy for everything, even when it doesn't actually teach what's being asked about.
It fills me full of such rage...  :blink:
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/457610-need-help-with-c/#findComment-6144757
