Hearthstone beginner deck guide?
I would go with either a zoo or a cancer hunter... they are fairly cheap and are usually really good.
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
Patron is cheap to make, but requires a lot of thinking to play.
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
I started with mage looks like the most balanced/easy one.
I recently started playing hearthstone and here is my mage deck (board control):
Arcane Missiles x2
Frostbolt x2
Acidic Swamp Ooze x2
Bloodfen Raptor x2
Arcane Intellect x2
Razorfen Hunter x1
Shattered Sun Cleric x2
Fireball
Polymorph x2
Chillwind Yeti x2
Gnomish Inventor x2
Sen'jin Shieldmaster x1
Water Elemental x2
Gurubashi Berserker x1
Boulderfist Ogre x2
Flamestrike x2
Stormwind Champion x1
Just play single player until you get to level 10 and you can build it.
I'm trying to play online (NOT ranked) but I'm getting destroyed every single time, I'm gonna go with SP for a while, and thank you for the deck, I'll try to make it as your's.
