I have not been able to connect to my samba drives (run form a windows 8.1 box) when i click network\windows network nothing shows up...check and the config file in samba looks like what everyone is saying on google...when i run "nbtscan 192.168.1.0/24" i see the server i want but i still cant get it to connect...any help is is welcome..thank you
https://linustechtips.com/topic/456946-linux-mint-sumba-help/
sounds like a password/login problem
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/456946-linux-mint-sumba-help/#findComment-6132351
Try typing the IP of the mint box. I have the same problems occasionally with Ubuntu Server and typing the direct IP usually loads it back up immediately.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/456946-linux-mint-sumba-help/#findComment-6132390
i've spent some time on this issue myself.
ant the problem is in how well samba is supported... on the windows side...
theres this issue within samba -that mostly shows up when logging in anonymously for some reason- where a windows server cannot properly detect the samba version of the linux client, and things go derp.
in some very rare cases this even happens between windows serverside and windows clientside.
i have two near identical laptops, one of them connects fine to my samba server, one doesnt...
the most reliable way of fixing this is to set parameters on your linux box to be the exact needed parameters (theres multiple threads of exactly this issue all over all linux forums)
a more permanent fix would be starting to use logins, whch magically resolves most of these issues happening...
as for the windows network tab... thats less reliable than buying vague chinese power supplies for a folding rig...
https://linustechtips.com/topic/456946-linux-mint-sumba-help/#findComment-6132458
