AIO or custom loop?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/456936-water-cooling/#findComment-6132118
AIO or custom loop?
I'd explain it but Linus does it better :D
Water conducts heat extremely well, so it can be used to cool components. You can find similar technology on cars.
Basic components of a PC watercooling loop is a block which is attached to a heat producing component, a pump that circulates the liquid inside the watercooling loop and a radiator which cools the liquid in the loop either with fans or passively.
There are other components but you can find a lot of information on the video linked above.
Thanks for such quick responses. Do you guys think you can maybe link me a all in one setup with a decent radiator that can cool an i7 4770k 3.5ghz
https://linustechtips.com/topic/456936-water-cooling/#findComment-6132247
https://pcpartpicker.com/part/nzxt-cpu-cooler-rlkrx6101
https://linustechtips.com/topic/456936-water-cooling/#findComment-6132261
welcome to the Linus Tech Tips forums!
please review these pinned topics in the Watercooling section:
http://linustechtips.com/main/topic/1755-water-cooling-101-a-good-place-for-newbies-to-start/
http://linustechtips.com/main/topic/5435-watercooling-faq-some-basic-qa/
then come back and ask questions, hashing items you are not familiar with
will be an awful experience for you.
https://linustechtips.com/topic/456936-water-cooling/#findComment-6132318
