Hello Community,
                            I need help finding a good case compatible with the MSI H97 PC MATE ATX LGA1150 Motherboard http://pcpartpicker.com/part/msi-motherboard-h97pcmate. I need it to be compatible with the usb 3.0 header the motherboard sports. All help is appreciated, thanks.
https://linustechtips.com/topic/456924-help-with-finding-a-good-case/
fractal design define s
s340
h440
enthoo pro m
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Form Factor?
It can only be ATX Mid or Full tower.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Hello Community,
Define S
Define R5
H440
S340
Air 540
Around $40-$80, I am still deciding.
s340 is the best choice in that range.
