Ok, so I'm giving my current build to my brother once I get out of the military before Christmas. I'm wanting to get a head start on my new build since major sales are about to start hitting the web.
So my biggest problem right now is deciding on what CPU to get. I'm wanting to get into 4k gaming. The build I have currently has a I7- 4790k @ 4.00GHz. When I was looking for best performance for gaming, I'm seeing a lot of people saying go with the I5s. Cpus are about the only thing ive been having trouble with understanding what the hell everything means. lol
So question is, what the heck should I buy for a great Cpu, I'm more of an Intel guy as I'm more familiar with them.
https://linustechtips.com/topic/456732-need-help-picking-a-cpu/
For 4k gaming I hope you've got SLI 980 Tis ready
EDIT: For 4k the CPU is the least important thing
https://linustechtips.com/topic/456732-need-help-picking-a-cpu/#findComment-6128698
Yeah, i currently got the 4790, and i havent had a single problem. And yes, in my upcoming build i will be getting the 980 Ti ;) Don't worry. haha Might even get 2 of them.
For 4K the MINIMUM is 2x 980 Ti - anything bellow that is 30 fps city
https://linustechtips.com/topic/456732-need-help-picking-a-cpu/#findComment-6128762
You see people recommend the i5's because they differ from the i7's only in that they lack Hyperthreading. As most games only scale well up to about four cores, Hyperthreading isn't usually something that has much of an impact on performance. You could go with an i5 and probably notice very little difference in most games, though if you have the money to spend for a 4790K I don't think it's an entirely dumb idea. In certain titles it can help smooth out the minimum framerates, at least.
You absolutely do not need the 5820K. You only need 16 PCIe lanes for two video cards, and if eight logical cores are already borderline pointless, twelve logical cores is even more so.
https://linustechtips.com/topic/456732-need-help-picking-a-cpu/#findComment-6128878
How does this build look?
http://pcpartpicker.com/user/Scottmalbon77/saved/HLcscf
And its saying I'm having to update bioms for something, ive never seen that before. Is that gonna be a problem?
if it hasnt the latest bios, you may need a haswell non refresh cpu in order to flash the latest bios that supports haswell refresh cpu at z87 boards.
To avoid the trouble, get a z97 board ( asus z97-a)
The site has changed....
https://linustechtips.com/topic/456732-need-help-picking-a-cpu/#findComment-6129184
