So when I am on skype with a couple of my friends and one is playing his guitar it makes my mic cut in and out but not the others.. Only me.. How would I fix this?
Pls Follow your own posts!      Chief Engineer for my School Studio, Own my own Home Studio also. I also do requests for Remixing songs too :D Storage Server: Mobo: Supermicro X8SIA-F Case: Some Supermicro 1U case Drives: 3x 2TB Seagate Barracuda 7200 RPM drives, 1x 3TB Seagate Barracuda 7200 RPM CPU: Intel Xeon X3430 2.4GHz Ram: 2x Kingston ECC 2GB sticks
https://linustechtips.com/topic/456236-skype-issue/
Are you using headphones when he is playing his guitar?  Or is your sound defaulted to the speakers?
Main Rig:
i7 4790k @ 4.4GHz w/ H75 Liquid CPU Cooler - Asus Maximus VII Hero - 16GB G.Skill Triedent X 2133MHz RAM - 2x Gtx 660s in SLI - 120GB Crucial SSD - 1TB WD HDD NZXT Hue - K70 RGB Keyboard - Corsair Sabre RGB - Windows 8.1 - 2x Asus VN247H-P 1080p Monitors (I'm a sucker for lighting effects)
Server:
FX 8350 @ 4.0GHz w/ stock cooler - 8GB Crucial 1600MHz RAM - AMD Radeon HD 7450 GPU - 300W PSU - 120GB SSD - Windows 7
https://linustechtips.com/topic/456236-skype-issue/#findComment-6122694
Headphones
https://linustechtips.com/topic/456236-skype-issue/#findComment-6122827
Headphones
Have you tried adjusting the gain or default format for the microphone?  Have you tried re-installing Skype?
Main Rig:
Server:
https://linustechtips.com/topic/456236-skype-issue/#findComment-6122865
Yep, I am using an external mic too... I am using a $200 condenser so I shouldn't have this prob lol
https://linustechtips.com/topic/456236-skype-issue/#findComment-6123157
Likely you have some sound leakage in your headphones, and your $200 condenser is picking it up and shutting off your mic.
Try turning volume down all the way so nothing is playing, and ask if its still happening.
If so.
Try turning off any "anti noise, anti echo" type settings in skype.
Also, if you are gaming.....I know that Skype is "the thing to use" these days with the newest generation of PC gamers, but... Maybe try something designed for gaming - Razer Comms, Discord, Teamspeak, Vent, etc etc. Just as a general friendly suggestion :)
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/456236-skype-issue/#findComment-6123455
If so.
Yeah I have been trying to get my friends to move over to TS so I can adjust their volumes because one of my friends sounds like he is on the ISS and his mic is in his house.. if you get what I am saying.. But they keep saying no because they don't want to change over..
https://linustechtips.com/topic/456236-skype-issue/#findComment-6128093
You may be able to convince with Discord. Its both an app, and also a website client. So, you dont even need to install so it's easy.
https://linustechtips.com/topic/456236-skype-issue/#findComment-6128512
Ehh I'll try :P
https://linustechtips.com/topic/456236-skype-issue/#findComment-6128522
