 I just noticed the game runs at an uncapped frame rate for some reason - any ideas if a V-sync option is available in the ini files? I'd like to run it 240 fps lower and 30*C cooler.
https://linustechtips.com/topic/455576-homm-v-frame-rate/
MSI afterburner +Rivatuner server.
Use Rivatuner server to CAP FPS by adding game EXE.
REDLINECore i7 6700k 4.8ghz 1.37v.Noctua NH-u12s.MSI Z170A Gaming M7.16GB Kingston Hyper X Fury Black.MSI Gaming R9 390 8GB Crossfire + GTX 780 PhysX.Samsung EVO 850 500GB SSD.Fractal Design Define R5 Midi Black.SeaSonic X Series 1050w Gold.Logitech G302 Deadalus Prime.Ducky DK2108 Zero Mech Cherry Blue.
https://linustechtips.com/topic/455576-homm-v-frame-rate/#findComment-6113566
that failed.
https://linustechtips.com/topic/455576-homm-v-frame-rate/#findComment-6113889
  • 4 years later...
Under User/"Username"/Documents/My Games/Heroes Of Might And Magic V/Profiles/"Profilename" you can find a user.cfg file. Thats the expanded options for the game and it offers a V-Sync option which is set to 0. Just change it to 1.
I know it's late, but maybe others find this topic some time when they search for that.
https://linustechtips.com/topic/455576-homm-v-frame-rate/#findComment-12955494
Guest
