I know there is a pinned thread, but I feel like it would be easier and simpler if there was a copy and paste format.
If this post is pointless it will be deleted, this is just an idea that came from another forum that I was apart of.
http://www.planetminecraft.com/forums/pmc-computer-building-general-information-thread-t387346.html
Format
What is this computer going to be used for?
List what you will be doing with your computer.
What is your budget?
Include amount and currency.
Where do you live? If in the US, do you have a nearby Microcenter?
Your country lets us know what sites you can order from. If you have a nearby Microcenter they have some great in-store only deals that you can take advantage of.
What is included in the budget?
Things like the tower, the OS, peripherals and monitors.
Will you be overclocking?
Overclocking will require different hardware than a non-overclocking build so we need to know this.
Will you be reusing any parts?
If you are reusing parts list them here.
What OS do you want?
Say which OS you want or say if you already have a copy of one.
Any specific case preferences?
Size, color, etc.
Any other special features that you want in the build?
Stuff like an SSD, large hard drive, RAID, and wifi
And as I've said before if this is useless or not posted in the right place it will be deleted.
TheGrim123321
CPU: I3-4170Cooler: Hyper TX3Mobo:Biostar B85MGMemory: G.Skill Ripjaw 2x4GBStorage: Barracuda 500GBGPU: Zotac GTX660Case: Fractal 1100PSU: Evga 500WMonitors: FHX2153L 21.5"│V193WEJb 19"Keyboard/Mouse: CMStorm DevastorAudio: MonoPrice 8323Microphone: BlueYeti BlackoutOS: MSX(Win10) Quote me or @TheGrim123321 to get my attention.
https://linustechtips.com/topic/454876-pc-build-plan-format/
-reserved-
TheGrim123321
https://linustechtips.com/topic/454876-pc-build-plan-format/#findComment-6102841
We have something similar already but it isn't in-depth but will do.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/454876-pc-build-plan-format/#findComment-6102909
