ok so i have a 300mbps TP-link tl-WN881ND wifi card and when i first installed it, the internet was fine. it was super quick and i loved it. then my computer got filled with so much malware, trotions and viruses and stuff like that, that i had to whip my hard drive and re-install windows and now my internet is just not the same. i avarage around 32mbps and it varies from 1-72 mbps. please help because i dont know how to fix this issue... im running 64bit windows 7 ultimate
amd sapphire 79 270 gpu
8gb crucial ballistics ram
500W psu
Gigabyte 970A-UD3P motherboard
amd FX6300 black edition cpu
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/
whats your internet speed?
and did you re install the drivers for the card?
Specs
CPU-Intel I7 4790K- @ 4.5Ghz / Mobo - Asus Maximus Hero VII / GPU - GTX 980 @ 1592MHz / RAM - 16Gb Corsair Vengeance Pro @ 2400Mhz / Cooler - Corsair H105 / SSD - Samsung 250gb 840 EVO / HDD - 2x 2tb Seagate/3x 3tb Seagate / PSU - Corsair RM1000 / Keyboard - Corsair K70 / Mouse - Corsair M65 / Case - Custom Glass panel Corsair Obsidian 750D -  Still saving for upgrades =)
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100362
That is why virus protection was invented.
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100390
my internet speed of my router is 300mbps but im litteraly getting 42 mbps right now. i have updated and re-installed all drivers thismorning and it did not help
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100507
not your router dude your actual internet speed, your router could be 7 billion gbs but if your internet speed is only 10Mbs you will only get like maybe 1Mbs around there
Specs
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100512
i think the internet speed we have got is 200mbps and that is what i was getting before the malware
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100542
ok, can you run a speed test for us please, on the laptop. PC
http://www.speedtest.net/
and post a screen cap of the results
Specs
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100616
ok dude do you have a computer not on wifi to run another speed test on?
Specs
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100730
You should test between a wired PC and the wireless PC if you have two PCs on your LAN (Home network). Using your WAN (Outside) connection to test is going to be quite random and your testing a lot more than just the wifi connection. Just transfer back and forth a multi-gigabyte file and multiply the MB/s speed windows eventually says by 8 to get your mbps speed of your wifi.
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100740
i wish i did :/ so sadly not I'm afraid
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100742
device manager....and yes....a wired connection to the router would help us determine a few things
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100753
Can you check the crude signal strength from the PC side and router interface. What wifi router/wifi ap do you have by the way?
http://www.linksys.com/ca/support-article?articleNum=136766
it says on mine that it is 150mbps and i have a standard sky wifi router
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100808
Just to make sure have you checked to make sure the antennas are tightened moving them around can make them loosen pretty easily. To tighten you need to grab the knurled part which is right where the connector is.
Does your router look like this? http://www.sky.com/shop/broadband-talk/sky-hub/
https://linustechtips.com/topic/454706-help-wifi-is-just-wrong/#findComment-6100863
